brake caliper help
Old Jan 10, 2010 | 01:57 PM
srosscamaro@aol's Avatar
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
brake caliper help
will front brake calipers from an 86 trans am fit a 82 trans am
Old Jan 10, 2010 | 02:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake caliper help
Yes.
JamesC
Old Jan 10, 2010 | 02:42 PM
Car: 85 trans am
was asking because i had already changed the rear end and the brake line fitting was different and i have the whole 86 trans am parts car here and was thinking id just change over the whole brake system on my 82 trans am
Old Jan 10, 2010 | 02:51 PM
JamesC's Avatar
According to RockAuto and Napa, the same front calipers are used 82-92. That said, there are line issues as you've experienced. And I doubt that the 86 combination valve will be a bolt on since it'll be metric. In the long run, swapping the 86 system in might be a good choice, especially since you have a donor car.
JamesC
dbrochard
Sep 19, 2015 08:13 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
