I've got a 700r4 that does'nt want to kick down when i gas it like i feel it should. any ideas? i just got this car running after the guy that ownd it before me let it sit for 2 years. ive gone though all the fluids so i know thats not the issue.
Sounds like your TV cable. Mine wouldnt kick down either when I first got it back from the rebuild because the adjusted it wrong. Mine had way too much slack in it. There are many threads on here that talk about the proper way to adjust it. Hope that is your problem and not something internal. If he let it sit for two years then you may want to check the fluid level and condition as well. Hope this helps.
Quote:
i was just looking at thoses posts. looks promising. Originally Posted by mavcar38
Sounds like your TV cable.. thanks
there is also the site bowtie overdrives that has good info
