700R4 shift into OD too soon?
Old Jan 11, 2010 | 10:01 AM
86IROC57L98's Avatar
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
I have a 700r4 in my 86 Iroc and was just curious on some knowledge. It feels like my OD comes in real early. it has been shifting throughout the gears real quick and finally into OD around 30-32mph when i drive around normally. is that a little early? i figured it would need to be around 40? is that adjustable with that TV cable on the throttle linkage? or is it fine the way it is now? thanks for all the help on here!
Old Jan 11, 2010 | 11:03 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: 700R4 shift into OD too soon?
Im willing to guess its the TV cable. Mine was shifting into OD too soon also. I re-adjusted the tv cable and it works great now!
Old Jan 11, 2010 | 01:09 PM
Car: 1986 IROC-Z28
Engine: 5.7L L98
forgot to add.. if it was the cable.. to make it shift later, would you take slack or give out slack on the adjuster? thanks for the answer!!
Old Jan 11, 2010 | 01:44 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Until you set it up properly you shouldnt be "fine tuning" it with a click here and there.
To set it up:
-Press the D button and push the adjuster as far to the firewall as possible.
-Rotate the thing that the throttle cable waps around on on the TB to WOT and you should hear a click.
Take it for a drive, and then fine tune it from there with either a click in or out.
Old Jan 11, 2010 | 01:49 PM
Car: 1986 IROC-Z28
Engine: 5.7L L98
oops.. totally forgot about this cuz i know it may amke a difference, my bad.. i have carbed 350 in it so its hooked up on a carb throttle linkage. the guy i bought it from swapped the motor.
Old Jan 11, 2010 | 08:57 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
i dont have a carb, so im not sure if it will make a difference, but id like to guess it doesnt. basically the tv cable needs to be tight at WOT.
There are tons of sites and threads on here about adjusting the tv cable for car or fi.
Old Jan 12, 2010 | 08:44 AM
Car: 1986 IROC-Z28
Engine: 5.7L L98
thanks man.. thats what i love about this place.. theres always an answer.
Old Jan 12, 2010 | 11:54 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Anytime.
I had such a hell of a time getting mine to shift right when i got it, always willing to help out a fellow f body owner with the knowlege i have gathered from working on mine.
Let us know how it works out for you.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
