View Poll Results: Which rear gear ratio?
3.23
30.00%
3.42
70.00%
Voters: 10. You may not vote on this poll
Which rear gear?
Old Jan 13, 2010 | 02:49 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Which rear gear?
Since I decided to build a motorcycle, my motor swap plans won't happen for another year or so. I still have the 305TPI and 700r4 and am looking into getting 4th gen rear end. I can't seem to find one with 3.42 but the 3.23 rears are everywhere. I currently have 3.27 gears in the car and like it but would I benefit more from a 3.42 ratio rear end? I'm not sure if it is worth holding out for a 3.42 when I found a complete 3.23 an hour away from me for $200. I know I shouldn't go too low with the gears or the car will rev through it's powerband too quick so what does everyone think?
The car is my daily (summer) driver until I get the bike built. It will see the drag strip once in a blue moon, I do a ton of autocross, and I hope to start doing HPDE events this year.
Old Jan 13, 2010 | 06:12 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Which rear gear?
you wont be able to tell much difference at all b/t the two. So if those are your only options, then go 3.23
I started with 3.42. Then bought a 4th gen rear with 3.23, swapped in some 3.73s and it still felt like the old 3.42s did.
Old Jan 15, 2010 | 12:20 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
why are you even considering swapping the 3.27 out for a 3.23? maybe a 3.42 you probably want even be able to tell the difference. 9 bolt is slightly stronger than the 10 bolt. i would stay with what you have right now unless there is something wrong with the rear.
Old Jan 15, 2010 | 01:56 PM
Car: 1987 IROC-Z
Transmission: TH350
The rear isn't worth keeping and I would rather run the wider rear then use an extra pair of spacers. My motor and any future builds won't make enough power to break the rear end. I'm also making the swap for the bigger LS1 brakes.
So, 3.42 won't make any difference? Do you know of a shift point chart comparing them or something. I'm not trying to sound like a smart ***, I'm just curious.
Old Jan 16, 2010 | 04:36 PM
3rdgenmaro's Avatar
Car: 88 IROC
http://www.corral.net/tech/gearcalc.html
For example, in Drive, doing 55 mph, with a 245/40/R17, with the 3.42s you will be turning 2560. With the 3.23 it will be 2415.
Play around with it if you want. You will not feel a difference.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
