4th gen Rear end Question
Old Jan 13, 2010 | 08:30 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
So im selling a moser 9 inch(its in the Classifieds), my question is, if its a 4 channel rear end w.traction control and someone wants to swap it back into a 4th gen that doesnt have trac. control, its technically not going to matter since the vehicle he has wont be sending the signal from the ECU to the rear end to engage the traction control correct? these systems work through ABS AFAIK, im just thinking logically here, the car will have ABS as usual and since it doesnt have any CBX for TC, it shouldnt engage.... anyone care to chime in on this?
Old Mar 9, 2011 | 10:19 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 4th gen Rear end Question
The 4th gen ABS is 3 channel and the Trac Control is 4. The regular ABS uses a single sensor in the rear pumpkin, but the 4-chanel uses 2 sensors: one at the end of each axle. Not only will Trac Control not function,...... but there would be no ABS at all.
Obviously not 'plug and play'. I don't know if there is any way to modify or splice the different ABS wiring/system to make it function properly......
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
