What do I need for a th350 swap from a th-200c
Old Jan 21, 2010 | 01:34 PM
massaku's Avatar
Car: 84 15th anniversary Trans Am
Engine: 305 H.O. L69
Ok so I guess that I am going to need to replace my transmission with my new 350 because it wont handle the power so....What all do I need to do the swap? If anyone has done it lay down the info!
PS why hasn't anyone made a sticky yet?
Old Jan 21, 2010 | 05:15 PM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
Re: What do I need for a th350 swap from a th-200c
Sent you a PM. I have a brand new Hurst swap kit that you need for the torque arm bracket. Let me know if interested.
Old Jan 21, 2010 | 09:17 PM
massaku's Avatar
OK thanks I will talk to my mechanic and see what he says.
Old Jan 21, 2010 | 09:35 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
instead of the bracket you could go with a spohn or umi torque arm system.
helps traction handling and handles the extra power.
then there is no need for anything else. should be able to use the same drive shaft
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
