TH350 Vacuum help needed.
Old Jan 23, 2010 | 01:48 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Ok I've read that if you have a manual valve body you can just plug off the vacuum on the tranny. On my car, the vacuum hose is just hanging. I'm not sure exactly what has been done to my tranny but I know it has a shift kit and it will shift by itself or can be shifted manually. If it had a manual valve body it wouldn't shift automatically right? I'm just wondering if I can plug my vacuum hose or if I need to hook it to the manifold. Can somebody help me out here?
Old Jan 23, 2010 | 03:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TH350 Vacuum help needed.
Does it shift late?
Old Jan 23, 2010 | 04:18 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Doesn't seem to, but that's just from driving it around the block several times. I've only took it out on the highway once and I was having problems with it not wanting to go into 3rd. I don't know if that has anything to do with it but the car sat up for a long time and at first it wasn't wanting to shift at all.
I just took it down the road a few mins ago and it shifted from 1st to second fine from what I can tell.
Old Jan 23, 2010 | 05:09 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
the modulator needs vacuum, hook it to a manifold source, and retest.
Old Jan 23, 2010 | 09:45 PM
Pro Built Automatics's Avatar
You must run the vacuum modulator if you want the transmission to shift correctly and have the transmission live. Running a TH350 or TH400 without the vacuum modulator is very hard on the front pump and sealing rings.
Old Jan 24, 2010 | 10:51 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Ok. Thanks for the info guys. I would have hooked it up already the hose just isn't long enough to reach. Now I know I need to go buy some. lol
Old Jan 25, 2010 | 11:54 AM
Jrgunn5150's Avatar
Car: 1989 RS
Engine: 5.0
Axle/Gears: 8.8 3:55
You probably just think you have a shift kit, because without the modulator, they kind of bang/lurch into gear.
Old Jan 26, 2010 | 09:46 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
really because my last camaro shifted really soft with no vacuum to it. not doubting just wondering wtf was wrong with that trans then.
Old Jan 27, 2010 | 12:16 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
a manual valve body wouldn't shift itself ever, correct? you need the vac line. i run it to manifold vac on my truck.
Old Jan 27, 2010 | 10:59 AM
Jrgunn5150's Avatar
Car: 1989 RS
Engine: 5.0
I dunno, lol.
A manual vb will never shift unless you shift it, correct. However, there are manual upshift/downshift vb's, and also manual upshift/automatic downshift vb's.
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
efiguy
Sep 27, 2015 01:30 PM
