Rear end wheel lug bolt broken?
Old Jan 26, 2010 | 03:53 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Noticed today that one of the bolts that the rim goes onto is broken, one of the 5 that gets lugnuts bolted down to them, is that bolt replaceable by itself or do I have to shell out for a whole new rear end, just the brake setup or what? Idk without taking it off, which isn't an option atm...
Old Jan 26, 2010 | 05:07 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: Rear end wheel lug bolt broken?
Not a big deal. You have to remove the brake drum/rotor to expose the hub. The wheel studs are pressed into the hub. Just use a hammer and punch to drive out the broken stud. You can then use lug nuts with washers under them to 'press' the new stud in.
Old Jan 26, 2010 | 05:12 AM
Engine: 3.8, 3.4
Ok, good to know, was concerned I might have to shell out big money to replace the whole hub or something, and I'm already $600 deep into the engine =/
Thanks for the help.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
