88 posi unit 10 bolt chunk swap
Old Feb 1, 2010 | 02:04 PM
ZTime's Avatar
I have a 1988 10bolt rearend with disk breaks, can I put the chunk into my 1985 Iroc Z so I don' t have to swap the whole rear end? Thanks
Old Feb 1, 2010 | 05:59 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 88 posi unit 10 bolt chunk swap
just as easy to swap the whole rear then do all the work with a gear set up.
Old Feb 1, 2010 | 06:47 PM
ls six's Avatar
You really have to pull the rear to set up new gears anyway.
Old Feb 1, 2010 | 09:17 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Also the 88 might be a 28 spline carrier instead of your 26 spline in the 85 carrier.
Mark.
Old Feb 1, 2010 | 09:23 PM
big gear head's Avatar
The '88 should be 26 spline too. You don't have to remove the rear end to change the differential. I've rebuilt several of these under the car.
One thing that you must know. You must know what the gear ratio is in both rear ends. The 2.41 to 3.08 gears use a 2 series differential and the 3.23 to 3.73 gears use a 3 series differential. If these rear ends don't have the same series differential then the swap won't work.
Old Feb 2, 2010 | 07:02 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Opps, Sorry I guess the 28 spline started in 89. But he should be OK if he changes out the Carrier and gears or what he is calling a "chunk".
Mark.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
knight72
Aug 10, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
