Truth About 700R4?
Car: 87 T-Top GTA
Truth About 700R4?
I have a 87 GTA with a BADLY rebuilt 700r4(too long of a story to get into), a buddy of a buddy is trying to tell me that a "700R4 out of a 89 Truck/Suburban is far superior to the stock one your car would have had."
Is any of this true?
I thought that GM only 3 different versions of the 700R4.
1)700r4, base tranny used for full size cars, small trucks and vans
2)700r4, 4x4 trucks, Super Duty/Full size Trucks
3)700r4, found on the Corvette, Iroc, GTA, (basically what GM would call there High performance tranny).
Please correct me if I way off here(cuz I probably am), I'm No 700R4 expert.
Re: Truth About 700R4?
The later model one should be a little better, I can't remember when they changed the input shaft spline count from 27 to 30. I know the 89 will be a 30 spline. I can't remember if the change was 86 or 89. It should be better then your early one though.
Car: 87 T-Top GTA
I think the point this guy is making, is that it would be better to rebuild a 89+ 700R4 instead of my 87.
Other then the years, I would like to why would the 89+ be better? I thought the 700R4 that came in the GTA, IROC and Corvette was the best that GM had to offer for automatic transmissions.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 87 T-Top GTA
Ah, yes, i forgot to mention that to in my last post......27 to 30 input shaft. And my tranny only had 74 miles on it when it broke.
So if I was to get a aftermarket tranny(direct bolt up), its best to get one with the 30 spline count. Correct? Which would need a matching 30 count torque converter?
Car: 87 T-Top GTA
http://www.tciauto.com/Products/GM/gm_4L60E.asp
The spline change may have happened in 84, from 27 to 30.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
700r4 was upgraded twice during the thirdgen years:
first in 1984 then the input went to 30 spline along
with some mechanical uprades,and again in 1987 when
further mechanical upgrades including an uprated
sprag,as well as a modified valve body and a pump
rotor with more vanes.
I would guess there is no difference between '87 and
'89 700r4s
'89 700r4s
The 1989 will have the type 2 valve body, as all 1998 -1993 units will have. The 1987 can have either. The early 1987's have the type 1, and the late 1987's had the type 2. You want the type 2 valve body. The later valve bodies had solved the shift timing problems that the type 1 valve bodies had. If you want to use the type 1 valve body, and have the shift timing problems solved, then install the full TransGo Shift kit (Green and Black box). I have this in the modified version for Heavy Duty use for type 1 valve bodies. The type 1 valve body in a 1987 transmission is the only one that I will not setup for Street/Strip use. For Heavy Duty use, it is fine.
Car: 87 T-Top GTA
Thanks PBA, thats some good info regrading type 1 and type 2 valve bodies. My GTA was built in May of 87 out of Ohio. Based on your given info, I would believe that my GTA came with the type 2 valve body. The chop shop that did my rebuild, most likely had another 700R4 rebuilt, and ready to go. Keep in mind, that tranny was most likely a base 700R4(out of a full size family car, small van or truck). I'm simply basing this on the MANY problems I've had with it since I got my back from them, and the fact that they STILL haven't been able to correct the shifting problems the 6 times I've returned it to them.
I may try 1 more time, and ask them to put a vette 700R4 88-90 tranny. At least that way it should have the correct springs, servo, and valve body in it, since they obviously DON'T know what model of the 700R4 go's into a GTA/IROC.
Wish me luck, they gave me a 1 year or 10,000km warranty back in the summer of 08. I've since been back there 5 times and put 1200kms from the time of the original repair/rebuild, costing me $1800.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
