1 piece and 2 piece rear seal flywheels
Old Feb 2, 2010 | 07:14 PM
badazz81z28's Avatar
Does anyone know. Is the clutch bolt pattern the same for the 2 flywheels? I bought a hayes 10-630 flywheel (11" clutch) but when I search for a 3rd gen Camaro no 11" clutch shows up.
Also anyone have a reccomendation for a good street clutch to handle 450ftbs Tq. 425hp?
Old Feb 2, 2010 | 09:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1 piece and 2 piece rear seal flywheels
the only specific clutch for a 3rd gen will be for a 153 tooth flywheel, 10.5 disc. AFAIK, its the only flywheel that will fit in the bellhousing
Old Feb 2, 2010 | 09:08 PM
Im not going to run the 3rd gen bell. Im going to use this 14" flywheel so I can use 11" clutch
Old Feb 6, 2010 | 08:28 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, i have a 350 in my 85 camaro and it's a pre-1985 engine so it's a 2 piece rear seal...i got a 14' flywheel with 168 teeth with the 2 hole bolt patterns to bolt the 10,5 standard clutch the T5 comes with...but i got a larger bellhousing (lakewood) to be able to fit the larger flywheel...
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Exxon Limited
Aug 9, 2015 08:13 PM
