auto cross rear end gearing
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: auto cross rear end gearing
I put 3.42s in my 12-bolt and I can run most configurations in 1 or 2 gears. With my 3.73s I was having to downshift and upshift more often as I ran out
of gear. I cam'd/intake'd my motor for a broad powerband also (2K->7K) so I use the engine RPMs to complement the gears.
YMMV
im running 3.42 gears now and dont seem to be able to launch out of the corner. my cam is for low rpm torque...somthing like 1500 to 3000. do you think that could be my biggest problem?
thanks
thanks
What trans gear are you in coming out of the corners? What Intake do you run? What's your car weight? If the cam is not matched to the intake, you may have trouble, especially if the car is heavy. Run your RPM/MPH numbers using a 3.73 gear, it might be the sweet-spot for you.
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
A General rule of thumb is to gear the car to top out at around 70 MPH in whatever gear your are planning on running. I have 3.42 gears, first gear is 2.42 and have 27 inch tall tires. I have never been out of first on an autocross course but I have also seen over 7000 RPM on occasion. I also don't have a lack of power coming out of slow corners and I don't have a torque grind cam in the car.
Car: 83 Camaro
Transmission: TH350
I do have a TH350, with a tight OEM convertor.
most of the time im running 2nd gear...but at the hill climbs i run 3rd with 1 or 2 corners that i have to shift down for and 1 place i need 4th. my intake is a stock duel plane winters off of a corvette i think. im probably close to stock wieght, i have stripped it down but then i put in a roll bar/subframe connector. not sure what you mean by run the rpm/mph numbers...
thanks for the info
thanks for the info
Car: 91 Formula
Transmission: TKO450
Axle/Gears: 4.10
http://www.kabamus.com/garage/gears.html
I think this is what he means. Its a calculator to see what your would be at a given rpm in each gear.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
