Can the 700r4 take this much power?
I m looking to buy another camaro and i came across a good buy i think but i am unsure about a few things.
Its a 1987 camaro it had the 305 in it but the guy blew the engine and swapped it out for a 5.7 4 main bolt engine with 4barrel 600 cfm putting out about 320 hp. The car has a 700r4 tranny and waht im wondering is if the tranny and everything else will be able to handle almost a double in hp?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Can the 700r4 take this much power?
Unless that tranny is upgraded then no way. I have gone through 2 trannies with a stock 350 with 3 inch exhaust... That tranny is either slippin real bad or 3-4 pack is gone.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It all depends on how you drive it, and what you do to it to improve its longetivity.
Well i drive pretty fast. I dont drive like a crazy person but i do like to put the pedel to the floor when at a red light til i get to the speed limit.
What can i do to improve it that would cost me that much and would be a fairly easy job if there is anything?
Car: 1991 GTA
Engine: SuperRam 350
You could later rebuild it with a trans kit, 9-clutch 2-3 gear kit or z-pack, high intensity band and 13 vane pump.
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Car: 1991 GTA
Here are a few examples or pretty cheap stuff that you can install yourself. Hope this helps.
http://www.summitracing.com/parts/BMM-70225/
http://www.summitracing.com/parts/BMM-70239/
or
http://www.summitracing.com/parts/BMM-70235/
http://www.summitracing.com/parts/FLX-3820/
or
thank you very much yes that helped!! Im only 17 and i havent had to much work on cars i mean i do know more then the avrg 17 year old but thats not saying much i just lack any serious exprience.. Are these that easy to put on?
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I have been very pleased with the service from www.700r4l60e.com ; contact them (Dana) to tap into a wealth of info on the 700R4 transmission.
Bill
Bill
Car: 1991 GTA
Bill
Bill
http://www.transmissioncenter.net/highperf700r4.htm
Alright well yeah seems to me that what everyones seems to be saying is that i shouldnt count on it with out a few upgrades first? and i should deffinatly find someone that knows what they are doing too...
Iroc8t8
Today 10:27 AM
sailtexas186548
Aug 24, 2015 10:11 PM
