Looking to buy a torque converter. But which one
Car: 91 formula
Engine: 350 tuned port. bolt ons
so im going to have my trans rebuilt at my local trans shop and I want to upgrade the torque converter so I need a suggestion on which one to get. my car is slightly modified nothing crazy just cold air,exhaust,ignition, and the car is daily driven. just was looking for something alittle better then stock. anyone have a suggestion on one.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Looking to buy a torque converter. But which one
Someone else will have to comment on whether it's a good option with a TPI motor - but I installed a S-10 converter behind my carbed 350. It was cheap from gmpartsdirect.com, and stalls at about 2100 rather than the 1300 stock from my RS.
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I'd go no higher then a 2100 stall for your application, TPI's make their power at fairly low RPM's so 2100 will get you a much better jump then stock. as for what one to get thats up to you, your trans shop should be able to get one for you, if not just call someone like jegs or summit and tell them your application. they carry TCI converters which are good quality.. oh and make sure its a lockup converter too, since its your daily driver you'll want to stay with the extra fuel mileage.
-Tim
-Tim
BumpaD82
Feb 26, 2016 02:57 PM
