B&M MEGASHIFTER QUESTION???
Old Feb 13, 2010 | 09:38 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
I searched and could not find a lagit answer...so i traded for a bnm megashifter...today i was messing around with it and noticed when i put it all the way down to first gear it had alot of play like it moves up and down still?? Is this normal or is the shifter messed up when i ratchet it all the way up to first gear it does the same thing it does not feel right so i wanted to see if anybody knows if this is normal on not?
Old Feb 14, 2010 | 10:57 AM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: B&M MEGASHIFTER QUESTION???
how old is the shifter? Megashifters are known for getting slop in them after some time.
Old Feb 14, 2010 | 11:26 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Mine is pretty sloppy as well, it drives me nuts.
Old Feb 14, 2010 | 12:03 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I got rid of mine and it was brand new.. Not a big fan. Cables got to be ran just right or it'll wear out fast and you can't get your car in gear (that was fun). Good luck.
Old Feb 14, 2010 | 08:08 PM
Engine: 350 tpi
well im getting it installed..i was just playing with it its pretty old it still gets all the gears and stuff...its just when its in low gear it will go back some....and when its in 1st gear it will move up some...is that normal..it almost feels like it wants to lock again but its already in low gear...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
