10 bolt upgrades
Old Feb 18, 2010 | 10:56 PM
challengerUSN's Avatar
Car: 84 trans am
10 bolt upgrades
what can i do to a 10 bolt to make it stonger? i was going to get a 9 inch but im running out of cash i am willing to try other alternetives, i am going to have a 383 stroker making about 400 hp what can i do?
Old Feb 19, 2010 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10 bolt upgrades
Check the following thread for a couple of links:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 19, 2010 | 09:12 AM
big gear head's Avatar
Install a 28 spline Eaton Posi, get a set of 28 spline axles, install a T/A Performance aluminum cover and don't use sticky tires. Be easy on it and it might live.
Old Feb 19, 2010 | 09:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
What do you think about a soild style crush sleeve instead of the regular ones that come with the rebuild kits ?
Old Feb 19, 2010 | 09:38 AM
It could help, but I'm not completely sold on them.
Old Feb 19, 2010 | 09:09 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Here are two good links.
http://www.ws6transam.org/10bolt.html
https://www.thirdgen.org/beefinguprear
If you believe guy in first link, you can upgrade rear to withstand around 400 hp. For all of the suggested upgrades you will probably spend around $1,100. An aftermarket axle that bolts in and would handle any power will be around $2,500 just to give you an idea.
Old Feb 19, 2010 | 09:46 PM
Car: 84 trans am
alright thanks for the help
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
