Boes Anybody Know what size Bolts?
Old Feb 22, 2010 | 10:14 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Im getting ready to upgrade my diff and install 3.73 gears an eaton posi and a performance diff cover. My question is does anybody know what size the ten bolts that hold the diff cover on are. I want to buy new possibbly stronger ones when i have this project done. Thanks for any of the help or info you can give....if buy some chance there is a company that sell these that you know of that would help also.
Old Feb 22, 2010 | 10:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Boes Anybody Know what size Bolts?
I'd suggest that the diff cover will come with the bolts--my Summit version did anyway.
https://www.thirdgen.org/forums/atta...-89-guides.jpg
TA Performance also manufactures them as well. The stud kit is extra apparently:
http://www.taperformance.com/products.asp?cat=48
JamesC
Old Feb 22, 2010 | 12:02 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
The stud kit for the T/A Performance cover is actually for the main bearing caps, not the cover itself. The cover comes with the cover bolts at the regular price.
-Levi
Old Feb 24, 2010 | 09:14 AM
Engine: 383 stroker
I bought a used cover and it didnt come with new bolts thats one reason why im asking
Old Feb 24, 2010 | 09:25 AM
JamesC's Avatar
Below.
JamesC
Old Feb 24, 2010 | 09:52 AM
JamesC's Avatar
(Just remembered that I have instructions) For my kit:
Some applications such as the Chevy 10-bolt, 7.5" diff covers will require the use of (2) 5/16-18NC x 1-1/2 hex head bolts (supplied) to mount the parking brake cable brackets to the rear end housing.
I measured the 'normal' bolts and they are as above only 1-1/4. No info on the bearing cap load studs, but as cal30 points out, they can be had in the above link.
BTW, if you'd like install instructions, let me know and I'll type them up.
Hey, I'm bored this moring:
http://www.summitracing.com/parts/SM...ts&prefilter=0
JamesC
Old Feb 24, 2010 | 01:04 PM
Engine: 383 stroker
So JamesC the ones in the link are for a 10-bolt diff cover.....Im pretty sure thats why you posted it im just checking...and im having this build done by a shop in my town so i dont need install insturctions ...thanks anyways though
Old Feb 24, 2010 | 01:21 PM
JamesC's Avatar
Yep.
JamesC
Old Feb 24, 2010 | 01:42 PM
Engine: 383 stroker
thanks for the help man.
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
