Reverse manual valve body??
Old Feb 24, 2010 | 07:22 PM
87irocz383's Avatar
Car: '84 Z28
Transmission: Turbo 350
Axle/Gears: 7.5/3.73 posi
Hi, I am wondering if I buy a reverse manual valve body, if I need to buy a shift kit as well? or if the reverse manual valve body IS the shift kit. Thanks
Old Feb 24, 2010 | 08:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Reverse manual valve body??
The manual valve body is the shift kit. The valve body is mechanically modified.
A manual valve body allows you to put the transmission in any gear. From a dead stop if you put it in 3, it will start in third gear and probably burn up the clutches. If you start off in first gear, the transmission will stay in first gear until you manually shift. You could red line the engine and it still won't upshift by itself. A manual valve body is intended as a race only item. The novelty of driving on the street and having to constantly shift gears in an automatic transmission wears off quickly. Forget to downshift from high gear all the way back to low at every stoplight a few times and you'll be putting new clutches in the transmission.
The reverse shift pattern changes the position of the forward gears.
Instead of PRN321, it's changed to PRN123. This means it's impossible to shift from high gear to neutral (or reverse) without slowing down and downshifting all the way back to first gear.
Old Feb 25, 2010 | 09:10 AM
87irocz383's Avatar
Car: '84 Z28
Thanks for your help clearing that up for me.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
mizz0313
Aug 12, 2015 06:45 AM
