im rebuilding my 92 700r4 and was wondering if the corvette valvebody is any different than the camaro one thanks
The shift timing valves are different between the two. (and there are other minor differences). They use different governors also. Depending on what Corvette valve body is used, the high performance valve body and governor are setup to shift at apx. 5,800 rpm at WOT, and has the TV plunger setup to have WOT 3-4 shifts. The Z-28 has a apx. 5,500 WOT shift point, but not the 3-4 WOT shift capability. This can be added, but was not offered from the factory.
