troubles removing Flywheel
Old Mar 3, 2010 | 11:33 PM
wabbitslayer's Avatar
Car: 87 Trans Am
Axle/Gears: 3.23 posi
Im having some troubles removing my flywheel, i have tryed useing an impact gun and a braker bar but the bolts wont come off and the flywheel keeps turning when i try to put alot of pressure on it.I also had a friend come over and try to hold the flywheel but the bolts didnt move. is there some way to stop the flywheel from turning?
Old Mar 4, 2010 | 12:28 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: troubles removing Flywheel
this tool http://www.summitracing.com/parts/WMR-W80510/
mine is made by matco so i don't know about the quality of this one.
Old Mar 4, 2010 | 01:07 AM
toomany's Avatar
If the impact gun won't remove them...I think it's time to upgrade the gun. Have you tried putting a breaker bar on the balancer bolt and have someone hold that?
Old Mar 4, 2010 | 05:55 AM
EvilCartman's Avatar
Car: '82 Z28
Same one I bought, had to trim the flat spring a little bit since it sticks out too far. Other than that, it's been fine and a time saver.
Old Mar 4, 2010 | 09:27 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
you could try to stick a bar or large screw driver thru a hole on the flywheel and bind it against the motor, thats always worked for me.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stangski09
Nov 14, 2015 01:27 PM
Stryker412
Sep 7, 2015 09:11 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
