Ford 8.8 axle to replace the 7.5
Old Mar 8, 2010 | 12:10 PM
ck88camaro's Avatar
Moved over to fabrication board.....
Last edited by ck88camaro; Mar 10, 2010 at 12:33 PM. Reason: moved to proper board.
Old Mar 8, 2010 | 01:06 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
Re: My ford 8.8 build
cool! i want to do a similar build do u think you could post the dimensions of the axle tube spacers? Also what year did that axle come out of? I may have a couple more questions. Anyinfo would be great and it looks great.
Old Mar 8, 2010 | 02:51 PM
ck88camaro's Avatar
For the axle tube sleeves all I did was take a few measurements inside the ford axle, and used the measurement in between my lowest and highest readings, which was 2.880". I used the same procedure on the outside of the camaro axle to arrive at my inside sleeve diameter which was 2.639. Every axle will be some what different though.
customblackbird
Aug 15, 2021 10:16 PM
toronto formula
Nov 10, 2015 06:17 AM
Reborn756
Sep 4, 2015 03:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
