323 gears
Old Mar 12, 2010 | 07:27 PM
dfitch's Avatar
Car: 92 RS, 01 huyndai, 96 acura, ect...
Engine: 305 tbi
323 gears
So what do you think 323 gears would do for my 1992 RS 305? I don't think it would be too much on the motor. I found one for $250, would you think it's a worth while investment?
Old Mar 12, 2010 | 08:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 323 gears
Probably, but check the following link for some things to consider
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 13, 2010 | 01:42 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Re: 323 gears
i have 3:23 and it gives me more top end speed, and im not gonna lie, my 92 bird has pretty good acceleration off the line too.
Old Mar 13, 2010 | 05:52 PM
dfitch's Avatar
Engine: 305 tbi
Re: 323 gears
My only real reservations are weather or not I'll have to modify the drive shaft and how to get my speedometer right.
Old Mar 13, 2010 | 07:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 323 gears
You replace the plastic speedo gears in the tailshaft of the transmission for the speedo correction (available from 700R4.com), and there's no modding necessary to the driveshaft to change rear end gears - but it's not something you can do at home - you have to pay a shop to properly shim the new rear gears on install - takes precise micrometers and special tools.
Old Mar 13, 2010 | 07:16 PM
92Firebug's Avatar
Engine: 305 TBI
Re: 323 gears
THANK YOU SOOOO MUCH! my speedo is off, i can drive like it is, but THANKS FOR THIS GREAAAT TIP!
Old Mar 13, 2010 | 07:58 PM
dfitch's Avatar
Engine: 305 tbi
Re: 323 gears
Well the whole rear end is being sold as a complete unit, I'm not just changing the gears in the pumpkin. is that still a job for a shop?
Old Mar 13, 2010 | 08:38 PM
JamesC's Avatar
Re: 323 gears
Swapping the rear is something a DIYer can do with a few basic hand tools, though air tools are a benefit.
JamesC
Old Mar 13, 2010 | 09:14 PM
dfitch's Avatar
Engine: 305 tbi
Re: 323 gears
That's what I thought I assume the most difficult part will be connecting it to the drive shaft, I always get nervous before undertaking a project I've never done before.
Old Mar 13, 2010 | 11:12 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: 323 gears
Everything about swapping a complete rear end is very easy.And I think you will be happy with the 3.23s.
Old Mar 14, 2010 | 08:51 PM
dfitch's Avatar
Engine: 305 tbi
Re: 323 gears
I hope so. I'm doing a 350 swap down the road but those gears should still do the job.
Old Mar 14, 2010 | 08:58 PM
92Firebug's Avatar
Engine: 305 TBI
Re: 323 gears
my only question for the experts is, if i put a manual in my car with my 3:23 gears is there anything different i should expect? is it a good combo with the gears and manual transmission? Thanks
Old Mar 15, 2010 | 01:37 AM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Re: 323 gears
I did this swap 2 years ago very happy since.go for it.
Old Mar 15, 2010 | 07:10 AM
JamesC's Avatar
Re: 323 gears
Been running 3.23's with a 350HO Deluxe for several years. Good all-around city/highway gears, IMO.
JamesC
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
