12 bolt axle install?
Old Mar 15, 2010 | 03:00 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I got my Moser 12 bolt rear today. The axles are in a separate box. I'm just curious is it a pain in the butt to install them? I haven't had time to even really open the box yet. Just curious...
Old Mar 15, 2010 | 04:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 12 bolt axle install?
I helped a friend put a Moser 9" into an '86 TA and another to put a Moser 12-bolt into a '98 Z28. Neither were particularly difficult as long as you take your time and pay attention to what you are doing. Putting the 12-bolt into the 4thgen is not really at all different than putting it into a 3rdgen.
It can be a PITA just because of the size and weight of it if you're doing it alone, but its still more than doable.
Old Mar 16, 2010 | 06:43 AM
Car: 1988 IROC-Z
Engine: 427 SBC
I thought since the rear said "complete" it would come with the axles installed in it already.
Old Mar 16, 2010 | 02:23 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Is there any difference whichone is easier to install,Moser 12 bolt or Moser 9 bolt?
Old Mar 16, 2010 | 02:29 PM
big gear head's Avatar
The axles are not installed because the brakes must go on before the axles go in. Moser always ships the rear end with the axles seperate. It's no problem to install the axles. If they are c clip axles then you remove the cover, remove the bolt that holds the cross shaft in place, remove the shaft, push the axles in, put the c clips on, pull out on the axles, put the shaft back in, put thee retaining bolt back in, torque the bolt to 25 foot pounds, install the cover and it's done. If they are not c clip axles then you just slide the axles in and install the 4 bolts that hold them in place.
Old Mar 16, 2010 | 04:07 PM
Car: 1988 IROC-Z
Engine: 427 SBC
You're the man! Thank you.
Old Mar 17, 2010 | 02:55 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Well I have no grooves on my axles, so I'm guess they're not C clip axles.
Old Mar 17, 2010 | 03:01 PM
Are the bearings pressed on the axles or are they inside the housing ends? If they press on the axles then you don't have c clips. If you are using disc brakes then you might need to install the caliper brackets before pressing the bearings on the axles. If you are using drum brakes then you might need to modify the backing plates, depending on which brakes you are using.
Old Mar 17, 2010 | 07:05 PM
Air_Adam's Avatar
Axles using 9" housing ends require bearings pressed onto the axles, but its not done at the factory, as some brake brackets must be put on the axle before the bearing is pressed on. Found this out on that 9" I spoke of in my first post... he had the bearings pressed on, then had to have them pulled off again to put on that caliper bracket first.
Old Mar 18, 2010 | 08:50 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks again guys! You're helping me a ton. A few more more questions, what exactly is this and where does it go?
Unless I'm missing something in the box, the directions I got are pretty poor. Also, what part of the Brakes have have to go on before the axles are installed? Just the caliper brackets? Also, yes, the bearings are pressed on the axles (Do they go all the way in until they bottom out?). I'm starting to get pissed at the lack of instructions that came with this. That or either I'm a complete newb that sucks, lol.
By the way big gear head, by the time I read your PM it was too late, I already ordered. Sorry
Old Mar 18, 2010 | 03:02 PM
That is the retainer ring for the bearing. It goes on after the bearing is pressed on. It help hold the bearing in place. I wish you had ordered this from me. I could have gone over all of this before you ordered it so that you would know what needed to be done. If the bearings are already pressed on the axles then they will have to come off to get the caliper brackets on. The caliper brackets might need to be modified to work with these bearings. I don't know which brackets you have and I don't know which housing ends you have, so I don't know what you need to do to make it fit.
Old Mar 18, 2010 | 03:17 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks again! Yes, my caliper brackets have to be modified. I at least understand that part. I guess it's time to get my hands dirty! These are the instructions I got for the bracket: http://www.moserengineering.com/mose...maroBrakes.pdf
Thanks again, I really appreciate it.
Old May 23, 2010 | 06:06 PM
Car: 1988 IROC-Z
Engine: 427 SBC
For the love of god I cannot get it to go down all the way. The bearing pressed on ok. But the retainer ring just won't move anymore. Do you think I should heat it maybe then press it on?
Old May 24, 2010 | 07:29 AM
If you heat it you will destroy it. These are designed to be a tight fit. What kind of a press are you using to install it?
Old May 24, 2010 | 08:56 AM
Car: 1988 IROC-Z
Engine: 427 SBC
A very small one. I think it's better I take it to the shop. The bearings went in fine though. Thanks again for the reply! Just wanted to make sure I wasn't missing something. I still feel bad. I just should have got one from you.
hectre13
Dec 11, 2023 08:14 AM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
