Fluid suggestion for T5 with worn synchros?
Old May 24, 2010 | 02:58 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The T5 in my GTA is creeping up on 150k miles, and as such, finding 2nd and 3rd gear isn't as easy as it used to be, especially on colder mornings. I realize that the trans is on borrowed time, and when I swap the 350 from my IROC into the GTA, the nicely rebuilt T5 in the IROC is going with it, so I really just need another year or so out of this trans. Now that the rear seal is leaking, I'll be fixing that and that'll necessitate new fluid anyway. That being the case, is there something other than standard ATF that will help the syncros work a little better until I can swap boxes? Maybe a thicker oil of some sort?
Old May 24, 2010 | 03:03 PM
vanimal's Avatar
Re: Fluid suggestion for T5 with worn synchros?
gm syncromesh works for the rice burners.
Old May 24, 2010 | 03:04 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
If its harder to shift when it cold you need a thinner oil when oil is cold its thicker and vise verse.
Old May 24, 2010 | 03:06 PM
Jim85IROC's Avatar
Good point. Maybe I'll just use some synthetic ATF and put up with whatever I get for the time being.
Old May 24, 2010 | 03:10 PM
Car: 92 camaro B4C
Transmission: t5
You never want to go thicker i tried that once on a ford t18 that was making nose i couldn't get that thing to shift for the life of me.
Old May 24, 2010 | 03:17 PM
vanimal's Avatar
weird, syncromesh worked great in my honda, my explorer, and my ranger.
Old May 24, 2010 | 03:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've been using Mobil 1 for a number of years without complaint.
JamesC
LittleFranks
Sep 17, 2015 12:22 PM
someone972
Aug 30, 2015 12:52 AM
CrispyClutch
Jan 30, 2003 10:57 AM
DuffMan
Sep 20, 2001 08:47 AM
