I got a 1992 700r4 Trany from a yukon
Old May 23, 2010 | 01:23 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Hey yal,
I just purchased a early 1990's 700r4 Trany from a Blazer/Tahoe/Yukon/Suburban Chevy truck, It has an magnetic type Speed Sensor, part #08673299. My question is this. How can I get it to work in my 1986 4bbl Trans Am and utilize the trannys Speed Sensor. I have the red drive(17) and red driven(37 thooth) gear to replace it, I had a problem before with the original tranny, when someone installed the red drive 17 tooth gear, it must of been inserted 1 centimeter (my guesstimate) too deep and thus worn my driven gears (3 of them quickly) and my speedo did not register MPH. Not i'm pretty sure of this cause my gears were worn at an angle(pic).
what can I do?
Attached Thumbnails I got a 1992 700r4 Trany from a yukon-driven-gear-worn.jpg   I got a 1992 700r4 Trany from a yukon-drive-gear.jpg
Old May 24, 2010 | 12:38 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: I got a 1992 700r4 Trany from a yukon
was it 2wd or 4wd?? Since it seems to have the speed sensor on the trans it self it sounds like you got a 2wd trans. You might check the length of the output shafts to make sure they are the same length. you will have to swap tail shaft housings to use the mount provisions to hook up the torque arm. Does the reluctor wheel (the round notched part on the tail shaft that the speed sensor read upon) look like it could be removed?? Otherwise if you use the truck speedo system you might have to get a converter box which can be very spendy last time I checked.
Old May 24, 2010 | 04:25 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I'm not sure when they stopped doing this but there shoudl be a hole drilled in the output shaft where the reluctor wheel is pressed on. This hole allows for a metal clip to hold the drive gear on the output shaft. You will definately have to swap the tailshaft housing as stated above. The reluctor wheel will pull off to reveal the hole if its there.
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
