Help! How can I get this drive gear off
Old May 23, 2010 | 07:34 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
How can I get this drive gear off.
its a 700r4 from a 91-93 chevy truck
I see there is a little hole for a drive gear clip. Is that correct?
Attached Thumbnails Help! How can I get this drive gear off-sam_0789.jpg   Help! How can I get this drive gear off-sam_0788.jpg
Old May 24, 2010 | 04:28 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Help! How can I get this drive gear off
You can either use a long two jar puller or do what I did. I used a cutoff wheel and cut the reluctor wheel until it just bareley got to the output shaft then I pried it apart. I knew I wasn't going to use mine so it didn't matter if I broke the ring.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
