U Joint
Old May 22, 2010 | 09:56 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
U Joint
Hey guys I need to replace my U Joint. I'm running a th350 in my car and I know the driveshaft is different so how do I go about buying one? Are they the same as what came stock on the car?
Old May 22, 2010 | 10:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: U Joint
where did the driveshaft come from that works with the th350? what sizes are on it? no way for anybody here to tell you what u-joints you have with aftermarket parts.
Old May 22, 2010 | 10:06 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: U Joint
Oh I have no idea. the tranny and driveshaft were in the car when I bought it. So I just need to measure the u joint? Never had to replace one before.
Old May 23, 2010 | 06:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: U Joint
you should be able to measure the overall width of the joint and the diameter of the ends ti find a replacement. Its possible its a stock shaft from a early 82 200r4 auto car, they apparently fit.
Old May 24, 2010 | 05:42 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: U Joint
Thanks. The previous owners said it was custom made so I don't know. I'll just have to measure it.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
