Having some trouble with my tranny swap
Old May 23, 2010 | 06:27 PM
sidewok's Avatar
Car: 1987 Camaro
Engine: 305 carbureted 4barrel V8
Ok, so a couple of weeks ago, I asked for some help on here. And everyone was extremely helpful. So, I finally got around to making the swap but am having some issues. To clarify, I am just switching my t-5 for another t-5 as my tranny is making noise in second and third and isn't engine braking properly. So I started taking the shifter out, draining the tranny, disconnecting wires and bolts around the tranny but just left on the cross member to keep the tranny from dropping. I disconnected those 4 bolts holding the 2 "u" shaped straps at the rear of the driveshaft... but the driveshaft wont move. I pushed and pulled, but nothing. I assume I am supposed to pull it from the axle first and then the transmission. I am getting frustrated and had to put it all back together to get home last night as I was doing the work at a friends and had no way to get home. taking the bolts out wasn't bad even though I only had floor jack, bow jack, and 2 jack stands to work with, but for the life of me I couldn't get the driveshaft to drop. Can anyone help me with this? thanks.
Old May 23, 2010 | 06:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Having some trouble with my tranny swap
its just a little tight, get a prybar between the u-joint and the axle yoke and pry the joint out.
Old May 23, 2010 | 06:53 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
What he said.
After it has been there for so long its wore itself into the carrier, and all the sludge, and gear oil that leaked out holds it in.
Old May 23, 2010 | 07:01 PM
sidewok's Avatar
Car: 1987 Camaro
so i was doing everything right? After I get those two "u" straps off I just have to ream on it with a pry bar to pull it away from the axle and it will drop down? Does that leave the "u" shaped joint attached to the axle and the "c" shaped joint where the straps were removed as the part that will pull away from the "u" shape and drop so I can just pull it from the tranny? Is there any bolt holding the drive shaft into the tranny or does it just slide out? Sorry for all the questions, but I don't wanna try again just to fail at another attempt.
Old May 24, 2010 | 04:40 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You will need to pry it away from the rear end and it will slide into the trans a little. Then you pull it out of the trans. It is on a splined shaft in the trans so it will slide fairly easily.
Old May 24, 2010 | 08:25 PM
sidewok's Avatar
Car: 1987 Camaro
ok, cool thanks. And thanks everyone else for the replies as well. I feel a bit more confident about my next attempt. thanks guys.
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
