linkage clutch question
Old Mar 19, 2010 | 11:42 PM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Alright, I think I know the answer to this question but before I go tearing this thing back apart I need to ask. Start the car, clutch depressed, can't get it all the way into gear (lets say 1st), tires begin to turn anyway (car is in the air). The linkage is adjusted as far back as it can go and then some... What did I do wrong when I installed the system? How do I fix it? Mind you, everything and I mean everything is new.
Clutch Assembly
Ram Clutches – Flywheel – 1530 11” SF11006483 RAM1.1 SFI SPEC 1.1 I006483
Centerforce – Clutch – DF148552 11” Dual friction
Lakewood – Bellhousing 15015 SFI SPEC 6.1 B060085 Manufactured APR 05
Lakewood – Clutch Fork Pivot Ball – 15501
Lakewood – Clutch Fork – 15500
Old Mar 20, 2010 | 05:13 PM
RaGiN Z's Avatar
Car: 83 Camaro
Re: linkage clutch question
So I ended up figuring it out. Basically what I ended up doing was adjusting the pivot ball to 4.5 instead of the 4.75 and then I bought a 10 inch 3/8-16 bolt from lowes and cut the head off about 1/2 inch down the shaft, then rounded the cut end. The stock actuator rod wasn't long enough at 9 inches. This seems to be an issue for some of the guys using centerforce clutches
this is the post I found that actually helped my issue
https://www.thirdgen.org/forums/tran...utch-wont.html
Drone358
Sep 1, 2015 02:50 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
