Can a clutch master be bad without visibly leaking?
Old Mar 21, 2010 | 11:47 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Welp, I started getting some grinding with a fast shift in second. And I knew that my slave was already leaking, so I replaced it, figuring that was the problem. But didn't help. I'm confident all the air is out of it and the line, and the pedel feels good. Anyway the master could be going/gone bad without leaking? Cause I don't see anything coming out of it. I'm kinda hoping it is that, cause I'm trying to rule out the cheaper/easier things before thinking a bad synchro. Oh, by the way, it's a T56 with T56 hydraulics.
Tom
Old Mar 21, 2010 | 11:53 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: Can a clutch master be bad without visibly leaking?
If your master was acting up you would get peddle slippage and so on
Sorry I can't add to it
Old Mar 22, 2010 | 12:00 AM
Gregzz4's Avatar
But you could replace your master if you don't mind throwing $ after some cheap tracing before you pull the Trans
LittleFranks
Sep 17, 2015 12:22 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
