700R4 Wont Go Into Park
Old Mar 22, 2010 | 03:29 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Problems been solved: Worn out shift cable.
Car is a 92Z with a 700R4, and we physically cant get the gear selector to go into Park. There's allot of resistance when trying to go into Park. Also the car will not start in Neutral. Any help or ideas are welcome. Problem came out of no where, as the car ran fine before this.
UPDATES:
-Removed the shift plate and the cables to the gear selector look fine
-Transmission has enough fluid
UPDATE:
-We manually put the car in Park and Neutral and the car started, so its probably the shift cable???
Old Mar 22, 2010 | 04:03 PM
ILLIROC89's Avatar
Car: 89 Iroc 78 z-28
Engine: 350 tpi
Axle/Gears: 2.77:1
Re: 700R4 Wont Go Into Park
I think you have a cable problem.Check to see if it starts in any of the positions P R N D321, your park may be reverse, and reverse may be netural, and so on. Should be able to adjust it out, unless it is broken, can you get the key's out of the car? Take shifter plate off and inspect pin that holds cable to shifter.
Old Mar 22, 2010 | 07:37 PM
Rich92 RS's Avatar
Transmission: T56's
Got back about an hour ago from advanced auto parts with the new shift cable's. Nearest store that had it in stock was about 45mins away. We ended up buying two cables because of how cheaply made these things are. And its a good thing too, because the first one broke within minutes of installing . Other than that the installation went fairly smooth and the cars up and running again.
Tips to future searchers:
-I recommend buying two shift cables just in case.
-Save the stock grommet, because the one that comes with the new cable sucks, and doesn't fit at all. (Just carefully cut a slit in the grommet to attach to the new cable)
-Care full around those plastic tabs, because they break very easily.
Old Feb 10, 2011 | 05:54 PM
neptunesnet2002's Avatar
i have the same problem but i manually put the car in all gears trying to start it and it never does
Old Feb 10, 2011 | 06:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yikes - old thread revived ....
For your starting issue, probably the neutral safety switch - it attached to the pass side of the shifter in the center console - two screws hold it in - it's adjustable to a degree.
I highly recommend GM dealer cables - went through 2 of the Autozone/Advance crap in a week, and finally bit the bullet and paid the stealership, but 3+ years now no issues, sometimes you do really get what you pay for.
Old Feb 10, 2011 | 06:57 PM
Rich92 RS's Avatar
Transmission: T56's
ditto.
You wouldn't happen to have a part number would ya? I tried searching for a gm one back then and came up with nothing.
Old Feb 11, 2011 | 10:01 AM
Car: 1992 RS
Engine: Carbed 350
Nope, sorry. At the time just asked parts dept for it and they ordered.
junior419
Apr 7, 2025 11:35 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
Fronzizzle
Sep 8, 2015 12:10 PM
