10 bolt 7.5" carrier series 2 vs 3
Old Mar 24, 2010 | 04:18 PM
mars061's Avatar
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
How do I tell which carrier I have. I bought it used without gears from a friend.
Any markings I should look at or maybe you guys know of a measurment I can take ?
Thanks !!
I want to order some 4.10's and don't know which ones I need.
Old Mar 24, 2010 | 04:27 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: 10 bolt 7.5" carrier series 2 vs 3
well you can count the number of teeth on the ring and I THINK divide it by number of teeth on pinion. That should give you a number. I believe the difference in carriers is defined in parts catalog by being 3.23 of numerically higher gear would be one type and 3.08 and lower would be the other. I think you divide the number though...if it comes out to be 2.73 3.08 3.23 3.42 then that's right, if it's way off try subtracting or multiplying them , but I'm sure it's divide.
Old Mar 24, 2010 | 05:01 PM
big gear head's Avatar
These are 12 bold differential cases, but the situation is the same. From left to right is the 2,3 and 4 series. Set your differential on a table and measure from the table to the top of the ring gear mounting flange. A 2 series for the 7.5 will measure about 1.67 inches and a 3 series will measure about 1.97 inches.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
