have an 87 iroc no kick down
Old Mar 29, 2010 | 08:26 PM
tenholewheels's Avatar
hi all i have an 87 iroc with a mildly built 355 and a th350
i use a holley dual feed 650 and i dont know where the
kickdown is.
i have looked and looked and scratched my head, i also run a B&M
megashifter.
i know this isn't a lot to go on but maybe some one can help.
not that i really need the kickdown..lol
thanks wayne
Old Mar 29, 2010 | 09:08 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: have an 87 iroc no kick down
On the th-350 there is no kick down cable or anything like that. The th-350 uses a vacuum modulator to help control the shifts. So i would check to make sure the vacuum line is attached, attached to the right place on the carb, and has no crack/leaks.
Old Mar 29, 2010 | 09:36 PM
thanks that is a good reason i couldn't find it..lol
i usually just shift it manually anyway, but sometimes my
wife drives it and i didn't want to hurt anything..
Old Mar 30, 2010 | 04:05 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Originally Posted by tenholewheels
sometimes my wife drives it
biggest mistake a man could make
Old Mar 31, 2010 | 09:37 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
uh my th350 has a kickdown
I didnt hook it up though. I just shift it manually if I want. Kickdown would probably just wreck me if I used it in my S10.
Old Mar 31, 2010 | 09:53 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
TH-350 does have a kickdown cable. I was told it needed to be hooked even if manually shifting. Dont know if that was true or not. The cable runs from the carb to the passenger side of the trans.
tcflint
Sep 14, 2015 04:55 AM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
fasteddi
Sep 2, 2015 10:29 AM
Glowsock
Aug 31, 2015 09:01 PM
mustangman65_79
Aug 11, 2015 03:17 PM
