Servo ?????
Old Mar 31, 2010 | 09:45 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Servo ?????
Is there any way that changing the Servo to a Corvette unit would change the shift points at WOT???In other words what did we do wrong?? This was the only change made, and the car does not want to shift now until extremely hi RPM's....Thanks, Tom
Old Apr 3, 2010 | 12:00 AM
Pat Hall's Avatar
Re: Servo ?????
I wouldn't think the servo change would affect the rpm of the shifts at all. Provided you didn't do anything to the TV cable setting when you changed the servo, I'm gonna guess you managed to get some debris stuck in the valve that's in the middle of the governor assembly. I just had the same problem with my trans, and it turned out that it had some crap stuck in the governor. You might've knocked some debris loose in the trans when you did the servo install. A stuck or defective governor will definitely cause it to shift at a crazy rpm.
Old Apr 4, 2010 | 03:03 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Servo ?????
thank you for the reply...........AND happy easter...........Not sure about the dirt.............Tom
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
