TV cable adjustment question
Old Apr 1, 2010 | 03:41 PM
DirtDawg57's Avatar
I have been having a lot of power problems with my car, you can find them in the V6 board, so I wanted to adjust the TV cable to see if that would help.
My car has always seemed to shift right, it shifted at 10-15, 20-25, 30-35 and 40-45 with the last being the torque converter locking I'm guessing. But my problem with it was when it was in OD and I floored it. It made no attempt to shift down, so it felt like I had now power to climb hills or pass.
So today I adjusted the TV cable by depressing the adjustment tab and pushing the slider as far back it would go. Then I opened it up to WOT but the slider didn't click at all. I then to it for a test drive and it shifted way different. It was a short test but it seemed like it was shifting at 20-25 with a hard shift, then around 35, and then at 55. I took it right home because I didn't want to hurt anything. I don't know what really to do for it since I tried to do the adjustment and it didn't click at all.
Is it possible to shorten the cable or something so the slider will click some, like maybe it has to much slack? Thanks!
Old Apr 1, 2010 | 08:05 PM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
Re: TV cable adjustment question
If you swapped the engine you will need tci sells an Edelbrock® carburetor TV Cable geometry corrector kit part number 376710.
part # 376700 700-R4/200-4R TV Cable Bracket - Quadrajet
check out summitracing i got both of my brackets there both brackets have to match up the the carb you have or are running on the vehicle holley edel ect.
Old Apr 1, 2010 | 08:54 PM
DirtDawg57's Avatar
Well, the story is it is all stock, and I think the cable is stock also. However the previous owner had the engine replace with a jasper create engine when the old one lost an oil pump. So maybe when the changed the engine the changed something or the cable.
If I found a way to shorten the cable so I could get the slider to click, would that work?
Old Apr 1, 2010 | 09:03 PM
diablood5's Avatar
Car: 1986 trans am
Engine: goodwrench 350, 4 bolt main.
have you tried to take it the other way and pull it out a little. i had to play with mine for a few days till i got it the way i wanted it
Old Apr 2, 2010 | 11:53 AM
DirtDawg57's Avatar
Problem solved! See V6 thread!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
