please help!!!
Old Apr 2, 2010 | 10:55 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
please help!!!
ok this is on my 94 fourthgen but you guys are the only ones i trust to help. I was driving home from school yesterday. took off on a hill and kinda chirped the tires then all of the sudden the trans high rev almost like neutral then it caught gear again and made a pop noise then all of a sudden i have absolutely no gears it will roll backwards in reverse and drive and just free revs in absolutely any gear anyone know what could be wrong???? this is the v6 3.4 dunno what trans it has from the factory
Old Apr 2, 2010 | 11:12 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: please help!!!
You should have the 4L60E ... same as the 700R4, just a new way of identifying it... looks like you broke something internally... you will have to rebuild....
Old Apr 2, 2010 | 11:15 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: please help!!!
you may have stripped the spines in the torque converter.
Old Apr 2, 2010 | 11:19 PM
Engine: L69 H.O
Re: please help!!!
thanks for the help guys im going to pull the pan and see what is in there. hopefully it is nothing insanely serious the trans worked perfect then just out of nowhere broke
Old Apr 2, 2010 | 11:24 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: please help!!!
That sounds like what just happened to my brothers truck. He broke the drum.
Old Apr 2, 2010 | 11:53 PM
Engine: L69 H.O
Re: please help!!!
how hard would that be to fix
Old Apr 2, 2010 | 11:55 PM
built91Z28's Avatar
Re: please help!!!
Its inside the transmission. I dont know exactly how hard because I've never done one. But I do know the trans has to come apart.
Old Apr 2, 2010 | 11:59 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: please help!!!
well since you're asking, it's something that you wouldn't be able to do the first time around... there are also special tools you need... the larger percentage of what it cost to rebuild a tranny is the labor cost of dropping the tranny... so if you're on a tight budget, perhaps one of your buddies can help you out and drop the tranny, a shop should be able to rebuild it for about 400-500 dollars, if you supply the parts... you could also maybe get lucky and get a good one from a junkyard...
Old Apr 3, 2010 | 12:22 AM
Engine: L69 H.O
Re: please help!!!
so a 700-r4 would be a direct swap?
Old Apr 3, 2010 | 12:40 AM
Re: please help!!!
no. you need a computer controlled transmission.
Old Apr 3, 2010 | 12:44 AM
Pat Hall's Avatar
Re: please help!!!
Actually no. KN's post is a little misleading. The shifts in your trans are electronically controlled, the 700r4 uses a cable to control the shifts. In short, they're not interchangeable.
Old Apr 3, 2010 | 01:12 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: please help!!!
thanks for the assist.... ....
actually doesn't the cable control the pressure and the governor the shifts...
Old Apr 3, 2010 | 01:48 AM
Pat Hall's Avatar
Re: please help!!!
The governor and the tv cable both kinda work in conjunction to control the shift points. When you're driving normally, the tv cable adjustment really affects the shift points because at part throttle, the line pressure inside the trans helps the valve body decide when to actuate a shift. So if the cable is adjusted wrong, the internal pressures are wrong, and the trans shifts at the wrong times. If your tv cable is set right, then the governor only takes complete control of the shift points when you're at full throttle and tv or line pressure is maxed out. That's when the springs/weights of the governor use centrifugal force and determine what rpm your shift occurs under full throttle. I'd say that's one of the advantages of the way the 4L60E is set up. You can read post after post on here of the headaches involved with proper tv cable adjustment on the 700r4. With a 4L60E the computer controls the shift points using solenoids in the valvebody to actuate the shift valves, so you never run the risk of misadjusting the tv cable and burning up the trans. If your car is bone stock, the tv cable isn't hard at all to adjust, but when you start playing around with aftermarket intakes and custom setups, it can be a real nightmare to get the damn thing set right! I just went through this after putting the Accel Super Ram on my motor. But even on a stock motor, a shadetree mechanic or novice can easily misadjust the cable and burn up a perfectly good trans! The 4L60E has flaws too, but getting rid of the tv cable was definitely a good idea. I can post on this topic somewhat knowledgeably now because of all the crap I just recently went through with mine regarding both the tv cable and the governor. Needless to say I did a boatload of reading online and in my ATSG manual.
Old Apr 3, 2010 | 09:02 PM
Engine: L69 H.O
Re: please help!!!
ok so i pulled off the tranmisson pan today and nothing but fluid and a couple really tiny metal flakes were in it the car will not do anything in any gear. it will roll fowards and backwards in every gear but park. i don't have a clue as to what happened to make it randomly quit.
Old Apr 3, 2010 | 09:25 PM
Stephen's Avatar
Car: 87 GTA
Re: please help!!!
Jack the rear up, put the rear on jackstands & see if the driveshaft moves. Chances are it won't, but it never hurts to narrow the problem down to the tranny or the axle.
Sucks to rebuild one & find out its the other.
Old Apr 3, 2010 | 10:03 PM
Re: please help!!!
there will not always be a ton of debris in the pan with a break like that. if the converter stripped then there would be no way for the particles to flow into the pan.
