Bolt sheared off in pin
Old Apr 6, 2010 | 05:23 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I'm taking my rear end apart. i start un scerwing the small bolt the holds the large pin in between the spider gears and only half of it came out. Any one ever have this problem before and know an easy fix ?
Old Apr 6, 2010 | 05:36 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: Bolt sheared off in pin
Same thing happened to me a while ago. As far as I know the only thing to do is use a BFH and a drift and beat on the end of the pin untill the rest of the bolt snaps off. Remember to block the front wheels of the car well to prevent it from moving forward and slipping off of the jack stands. That almost happened to me. Good luck
Old Apr 6, 2010 | 05:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's SUPER common.
I had it happen to me. I think I was lucky, in that the rest fell out. Otherwise you'll have to beat on it, or try to drill it out with a 90* drill? Then just replace the pin, it's about a $20 part.
Old Apr 6, 2010 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.etoolcart.com/fabbri-diff...actor-kit.aspx
JamesC
Old Apr 6, 2010 | 05:59 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Thanks guys.The whole rear end is getting rebuilt and I have all new parts going in so beating the crap out of it dosent sound that bad.
Old Apr 6, 2010 | 07:47 PM
big gear head's Avatar
Check this out. http://www.nastyz28.com/forum/showthread.php?t=107063
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
