rear diff cover magnet. and do I have pos pix inside
Old Apr 7, 2010 | 09:07 PM
Thirdgen6.6l's Avatar
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
I change my rear diff today and pop the cover, find out that that donut magnet one side is smack and punch of break peace stick to the magnet. no gear teeth damage, but just wonder where I can get a replacement, mabe a small version of it.
btw how my rear diff look ?
Old Apr 8, 2010 | 06:05 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: rear diff cover magnet. and do I have pos pix inside
it looks fine. Not a posi
Old Apr 8, 2010 | 09:12 AM
so it mean i dont need add any addictive to it ?
Old Apr 8, 2010 | 09:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
JamesC
Old Apr 8, 2010 | 10:29 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
What is the downfall (if any) (or benefit) of having a fluid with Limited Slip Additive in an open diff? I searched but couldn't find much.
I am using this from Royal Purple. Which has a Limited Slip Additive in it. Let me know. Thanks.
Old Apr 8, 2010 | 11:24 AM
its just add more protection because you use a quality synthetic fluid, my choice of gear oil is redline 75w90,
Old Apr 8, 2010 | 03:51 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
How do you guys clean the inside of your diff. I was wondering if there is something I can spray at the gears and such to clean it a bit without removing it. I am going to be installing my new Moser Diff Cover and RP Fluid, but would like to clean it up if I can without having to disassemble more than the diff cover. If nothing then Ill just replace the cover and gasket and put in the new fluid.
Old Apr 8, 2010 | 04:46 PM
Twin_Turbo's Avatar
Limited slip additive is a friction modifier, it allows some slipapge in wet clutch pack systems so the clutches don't chatter, or hammer as some call it. That's all. No posi? Don't need it!
Old Apr 8, 2010 | 05:06 PM
Originally Posted by I H8 WWD
How do you guys clean the inside of your diff. I was wondering if there is something I can spray at the gears and such to clean it a bit without removing it. I am going to be installing my new Moser Diff Cover and RP Fluid, but would like to clean it up if I can without having t disassemble more than the diff cover. If nothing then Ill just replace the cover and gasket and put in the new fluid.
I alway spray it with brake cleaner and wipe each gear teeth down with that blue paper tower. depend how dirty its, I spray whole can of brake cleaner on it .
Old Apr 8, 2010 | 06:10 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Just did some work to my Diff a few days ago. Used 2 cans of non-chlorinated brake cleaner and got as much of the old oil and what not out of it as possible. Since I changed my outer axle bearings so I sprayed down the tubes and packed/shoved a rag down them also to clear out everything.
As stated, no posi = no need for slip additive, you are just wasting your money.
Old Apr 8, 2010 | 06:28 PM
big gear head's Avatar
If you do spray it out with brake cleaner you better let it sit with the cover off of it for about a day or more so that all of the brake cleaner evaproates. If any brake cleaner is left in the rear end it will cause a chain reaction break down of the oil and then you will have big trouble. The brake cleaner will get in the space between the pinion bearings and it may not evaporate. There is no way to clean out this area without disassembling the rear end.
Old Apr 8, 2010 | 06:32 PM
Very true! Mine was all done completely disassembled. even though it looked dry I was still able to wipe and shake residue out of the bearings.
Old Apr 12, 2010 | 09:10 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Ill just change the fluids for now then. Thanks guys.
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
E Rod
Aug 28, 2015 05:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
