Need to find some bolts for T-5 swap
Old Apr 25, 2010 | 02:35 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I found the size of the bolts i need for the Tranny to bellhousing: BOLT,TRANS(M12X1.75X40) from http://www.compnine.com/index.php?u=...04&grouptype=B
Also the bolts on the flexplate will work for a flywheel right?
Also are there bolts I am going to need for the pressure plate as well?
But what grade should I buy?
I refuse to pay 5 bucks a bolt.
Old Apr 25, 2010 | 02:43 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: T-5 to Bellhousing bolts
Not sure its completely required, but I like the strongest bolt I can get. I would try to find 10.9 It's just a regular hex head bolt right? If so, I would just go to a local hardware store.
Old Apr 25, 2010 | 11:45 PM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
Those have the Torx in the head of the bolt also. That comes in handy for the upper right bolt when it's in the car, but you're car. If it was me, I'd just go to the dealership and pay the $20 for the bolts, better than the cost of everything else if those other bolts aren't strong enough
Old Apr 27, 2010 | 01:08 PM
JTNKTZ's Avatar
Engine: 355/350
Bump
Old Apr 28, 2010 | 07:54 PM
JTNKTZ's Avatar
Engine: 355/350
No one
1984HO
Mar 19, 2021 11:59 AM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
