700r4 connections are different
Old Apr 27, 2010 | 09:45 PM
jclifford3rd's Avatar
I am replacing the 700r4 in my 93 formula, the 700r4 that I bought is out of a 87 transam. The issue is the electric plug on the 93 transmission is a round 5 prong and the 87 is a square 4 prong with 3 used. How can I make this transmission work in my 93 formula. the new transmission does have a aftermarket stall converter and shift kit installed. What do these control, lockup ? Can the wires be adapted? Are they needed with the high stall converter?
Jim
Old Apr 27, 2010 | 09:50 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 700r4 connections are different
are you sure your 93 isn't a 4L60E equipped bird... ?
Old Apr 28, 2010 | 12:03 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
change everything over that's different with regard to speedo drive gear / reluctor and VSS. Shouldn't be tough w/ the tailhousing being bolted on.
Old Apr 28, 2010 | 12:13 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
does the 93 bird come with the 4L60E, if so it's controlled by the PCM, I don't think it will work,... will it?
Old Apr 28, 2010 | 06:51 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
a 4l60e wont work without a controller to control it. It would be like trying to run a 700r4 without the TV cable hooked up. Wont last long.
Old Apr 28, 2010 | 09:47 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I dont know for sure but I think 92 was last year for 700r4 and 4l60e came out in 93 sounds like you have one of each.
Old Apr 28, 2010 | 11:03 PM
Pro Built Automatics's Avatar
The 1993 Formula is a 700R4, it just happens to have the round 5 pin plug, instead of the 3 pin square plug of earlier years. I'm not sure how you would do this, so call me. 909 795-1876 anytime in the afternoon. Dana
Old Apr 28, 2010 | 11:18 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
x2 on the 93 being a 700R4. My 93 has the square plug though...
wigmobile
Feb 26, 2025 02:56 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
romcjr
Sep 17, 2015 05:18 PM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
