Posi
Old Apr 27, 2010 | 09:21 AM
W19TEY's Avatar
Posi
Hi I'm new to this site and was wondering how I can find out if my 82 camaro has a posi or not I've done a burnout and there are two big black marks but when I pull out of a junction and put my foot down only the inside wheel spins whichever way I'm turning
Old Apr 27, 2010 | 09:49 AM
big gear head's Avatar
Re: Posi
You can check for the G80 code on the RPO decal on the bottom of the console lid. This might also be located behind the spare tire cover. If you don't have the G80 code then it should be a standard differential. If you do have the G80 then it is probably an Auburn differetnial. These will wear out eventually and start allowing only one tire to spin. When this happens you either have to replace the Auburn or live with it spinning one tire.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
