tv cable
Old Apr 27, 2010 | 12:32 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Engine: 350 5.7L Carb'd
Axle/Gears: Disc 2.77
tv cable
i dont think i have one, so i have no idea where one is supposed to connect to, i know it is supposed to connect to my carb and to the trans, but i dont know exactly, could anyone show me where it connects onto the trans? cause i planned on ordering me a new one today
the transmission doesnt shift down at high throttle, and it doesnt always want to go into park, also takes a while for 4th to kick in, ive read a bunch on the tv cable, but cant find any info really on where it connects to on the transmission, or what i need to do to connect it precisely to my quadrajet
Old Apr 27, 2010 | 01:52 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: tv cable
On my transmission the cable went in to the transmission on the passenger side almost right above the back corner of the pan. It went in straight down from the top.
Old Apr 27, 2010 | 01:59 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: tv cable
are you certain you have a 700r4? might the previous owner have done a swap? you could have a module by the tailshaft of the tranny where a vacuum line connects ...
Old Apr 27, 2010 | 02:20 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Re: tv cable
thanks for the quick replies
no im not 100% sure, im just guessing, if that were the case, what would distinguish it from a 700r4 that i could tell just from a looking at the bottom? ill go out and look for a vacuum module in a minut
Old Apr 27, 2010 | 02:21 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: tv cable
IIRC... the pan itself will have an angle at one of the corners...
Old Apr 27, 2010 | 02:29 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: tv cable
https://www.thirdgen.org/forums/tran...tle-shift.html
Old Apr 27, 2010 | 02:32 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: tv cable
once you identify the tranny you can then start looking into getting a TV cable...
Old Apr 27, 2010 | 04:16 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Re: tv cable
yeah, its a 700r4, and i couldnt find a tv cable, or a place to put one actually, course i couldnt get far enough under the car to see, i did find another cable on the drivers side connected to it, but it looks like it goes to the shifter in the center console
Old Apr 27, 2010 | 04:32 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: tv cable
Uploaded with ImageShack.us
if you click on the picture and make it bigger, boxed in yellow is where the cable mounts...
Old Apr 27, 2010 | 05:05 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Re: tv cable
yep, found it, the cable has been cut off right above the little sleeve that goes around the base of the cable, yet ANOTHER reason to hate the PO... i found a cable for 22 bucks on special order through autozone, idk if i should get it though, since my system was originally tpi im not sure if it will fit right, and would i have to get some sort of adaptor to connect to my carb?
Old Apr 28, 2010 | 08:01 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: tv cable
yeah the PO was an idiot then. Unless he installed a manual valve body. Which from the sounds of things he didnt.
The TPI cars used longer cables, but they had the same connections. Id use one from a TBI car, they are shorter and will look a little cleaner.
Does your throttle bracket have a provision for the TV cable to hook to? (large square opening approximately 1") If not you will need to get one. Dont buy one of those cheap spectre ones, they usually flex a lot.
Old Apr 28, 2010 | 09:49 AM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Re: tv cable
thanks for the reply, yeah i do have the bracket, but im gonna need a new one, they twisted up the original
Old Jul 13, 2010 | 07:16 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Re: tv cable
i just now bought a tv cable, and a bracket, but i was wondering where it should connect to the carb at, is this it?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
