Towing with a t56
Old Apr 27, 2010 | 09:35 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Towing with a t56
I'm thinking about towing a wild mud s10 with a 5.3/t56 combo. Not a camaro, but I figured I'd get a no bs answer here. Its a strong trans, and strong is strong right? Its going in an s10 which have a factory rating of 5000 lbs.
What do you guys think? I'm thinking about selling my blazer and using this for any truck needs.
Old Apr 28, 2010 | 12:06 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Towing with a t56
As long as you know how to tow without burning up the clutch, you'll be fine. Keep your hydraulics well bled so the release is working tip-top.
Old Apr 28, 2010 | 09:19 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
You may want to consider 4.11 or 4.56 rear gears if you plan on towing close to that 5,000lbs. Note that the only 2 T56 factory truck applications (Dodge Ram SRT10 and the Chevy SSR) had larger output shaft sizes in their T56s, and still came with the lower rear gears to help moving a heavy tow load without stressing the T56 output. If your T56 is a fbody version (27 spline output) you need to be aware of the limitations.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
