Swapping a 9-bolt 2 series carrier for a 3 series carrier, what's involved?
Old Apr 27, 2010 | 11:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Is it as simple as removing the axles and swapping carriers? Never really been into one of these rearends, looking at my options. I have a 2.77 rearend now and I'd like to put 3.45 gears in it. Thanks guys
Will
Old Apr 28, 2010 | 05:08 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Swapping a 9-bolt 2 series carrier for a 3 series carrier, what's involved?
You have to swap the Pinion gear as well but yes its basically that simple. Take the axles out, unbolt the 2 series carrier and pull it out...unbolt the pinion and knock it out.. and install your 3 series gears and pinion of choice. Warning however...if you have never set up gears before i would have a shop do it since your going to be dealing with pinion bearing preload and shiming the carrier and pinion to get the tooth contact correct. Also if your already in there you might as well check the posi and if it needs to be tightened or not. No sense in going in their twice. Do it all the first time and be done with it.
By the time all is said and done it might just be easier to find a 3:45 rear already assembled and ready to run...but then again i have NEVER seen a 9 bolt by this time that does not need to be pulled apart and reshimmed to be tight again.
Old Apr 28, 2010 | 09:43 AM
big gear head's Avatar
You will have to swap the 3 series and 3.42 together. You will have to set the pinion depth, bearing preload and backlash again to get the correct contact pattern. This is very important. If you don't get it within about .002 inch you will have problems.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
