swaping brakes parts???
Old Apr 30, 2010 | 02:23 PM
92yellowcamaro's Avatar
Car: 1992 camaro rs, 1988 saab 900
Engine: 305 tbi 5.0L V8
hey all,
going to be doing a posi swap tomorrow and heres my little "problem"
the posi that is going in is a drum unit, the rear thats in is a drum unit.... on the posi the driver side brake setup crumbled when i took the drum off.(springs and brackets and shoes) question is can i take the brake setup off my old rear and put it on the new one... both are drum setups. any help would be great before i do the swap..
thanks
-Zach
Old Apr 30, 2010 | 02:28 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: swaping brakes parts???
Have you checked / compared the axle spline count?
Old Apr 30, 2010 | 02:43 PM
by axle spline count..... you mean? sorry if i don't know.. but i have helped a few friends in the past taking a rear out and putting one in so i know the basics of doing so, i made sure i got matching gears, now is 3.23 and the new posi is also 3.23... that's about it
Old Apr 30, 2010 | 02:58 PM
Wadebryant's Avatar
Not sure what car you're working on or what you have as a transplant posi unit but, the 90-92's had a higher spline count on the axles & limited slip (posi) unit. Just asking if your axles will slip into and accept the posi you want to use..?
Otherwise, your drum brake parts should swap no problem.
Old May 4, 2010 | 04:47 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
https://www.thirdgen.org/forums/tran...-gen-10-a.html last post has some info you might need. hth
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
