Servo ?
Old May 4, 2010 | 06:30 PM
chevy lovin's Avatar
Servo ?
Is the 87 z28 305 tpi servo the same as the corvette servo. i got a 91 van 700r4 in it now it was shifting early at wot. So i switched the governor from the original z28 700 that cured it, but it shifts a little to soft. the tv is adjusted right. any help would be great.
Old May 5, 2010 | 06:40 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Servo ?
I think the z-28 servo is the same as the truck servo, but not 100% sure.
Remove the servo assembly and compare the center piston and ring on the middle of the pic below.
If they are the same, it is a vette servo. If not, they are only about $15 or so.
The pic is a corvette servo.
Old May 5, 2010 | 06:59 PM
Re: Servo ?
thanks alot. is that is the one in the side of the transmission?
Old May 5, 2010 | 09:23 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Servo ?
If you need any help with the install heres a link=
http://sethirdgen.org/servo.htm
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
