1991 z28 speedometer not working
Old May 6, 2010 | 10:25 PM
clineracer's Avatar
I`ve got a 1991 z28 was originally a t5, now a t56 with 4.10 rear gears. I would like to know how to get the speedometer to work. When you first start to move it will peg out on 145mph, as you speed up it drops to zero. And help would be appreciated. Thanks, Dwayne
Old May 6, 2010 | 10:40 PM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
Re: 1991 z28 speedometer not working
The f-body T56 has a 17 pulse per driveshaft revolution VSS signal generator in the tailshaft. This has to get converted to a 4000 (or 2000) pulse per mile signal for your VSS buffer input. The easiest way is to purchase the Dakota Digital SGI-5 signal recalibration box to do this. This is just spliced in between the transmission and chassis wiring.
Care of: http://www.skulte.com/T56.html
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
