Prolly been covered, tried search
Old May 10, 2010 | 10:23 PM
sumnerslayer's Avatar
Car: 1982 Camaro Coupe, 2004 Grand Prix
Engine: 6.0 iron block LS, series III 3.8
Transmission: T56, 4T65-E
Axle/Gears: 3.42s<--hate em...need some 4.30s
ok so i got my t56 in this weekend and i had a nice long look at my clutch disc and decided a should probably hunt for another here soon, i currently have a centerforce 700107 for the 2 pc rms motor<--new, and a spec 3+ clutch and pp<---used, now heres my question, can i have the pp turned down and buy the disc seperatly??? i really wanna stick with the 3+ but spending another 500-600 on a new assembly is outta the question right now. (ole lady is naggin bout the cost of the t56 swap) can other discs be used with the spec 3+ pp?? Can i buy the Spec 3+ Disc seperate and have the pp turned?? If So anybody know where i can buy one??? Thanks
Old May 10, 2010 | 10:32 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Prolly been covered, tried search
i dont have the answers to all your questions but i can say i've never heard of machining the pressure plate. it would likely lessen the pressure on the discs causing slippage.
Old May 11, 2010 | 04:58 PM
so i'm probably stuck with buying a clutch and pp together?? that sux, really dont wanna spend a ton more money, maybe have to settle for a different setup
Old May 12, 2010 | 08:18 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm using the Autozone NU31265 LT4 PP (comes as a kit, but just use the PP) & Mcleod 261171 disc. Cost < $400 and doesn't slip on my setup.
LT1 T56 clutch info
Old May 12, 2010 | 03:27 PM
a guy at work today said i should be able to get the pp resurfaced at a machine shop......man i dunno anymore
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
