difficulty with installing drive gear on 700r4
Old May 13, 2010 | 03:05 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I am having my mobile mechanic replace the speedo gears after a rear end change, and he is having trouble installing the drive gear due to it being a very tight fit. He is coming tomorrow, and I want to have some info. Any info would be greatly appreciated.
Old May 13, 2010 | 03:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: difficulty with installing drive gear on 700r4
http://sethirdgen.org/vss.htm
JamesC
Old May 13, 2010 | 03:29 PM
Thank James, but what do I do with the "too tight gear" issue? It doesn't cover this on the web sight you gave me.
Old May 13, 2010 | 03:34 PM
JamesC's Avatar
You might reread. The poster says, "it is almost pressed on the shaft, so you will need something to help you remove the gear. I use a 32mm wrench to "tap" it off the shaft."
JamesC
Old May 13, 2010 | 03:36 PM
I read the tapping off the shaft. The drive gear had to be broken off it was so tight. Tapping wasn't doing the trick.
Old May 13, 2010 | 03:39 PM
JamesC's Avatar
I'm a T-5 kinda guy, so perhaps someone with 700R4 experience will drop in.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
