Slave cylinder revisited
I have a question about Russell fittings that Built91z28 suggested I use on my 1984-92 clutch slave cylinder. These fittings do NOT work! Are the cast slave cylinders different from the composite ones? I have a composite (plastic) cylinder. The fitting does not go in all the way. And the slot (on the fitting) doesn't line up with the expansion pin. What am I missing here?
Bryan
Bryan
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Slave cylinder revisited
Did you put any oil or brake fluid on the O-ring? If not I would try that. The fitting went in my master with no problem. I did have to push a little though for that last little bit. I dont have a slave so I cant comment on that.
Bryan
Yeah the turning is normal. The O-ring seals it, not pressure as if bolted solid. Glad you got it figured out. I would have hated for you to buy something that didnt work and have just wasted $20+
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thanks again.
